My pc spcs
so i fished my pc and decided to shear it with you guys to see if there are any improvements  i can make.
System Information
Time of this report: 5/11/2014, 13:25:59
       Machine name:
   Operating System: Windows 8.1 Pro with Media Center 64-bit (6.3, Build 9600) (9600.winblue_gdr.140305-1710)
           Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
       System Model: To be filled by O.E.M.
               BIOS: BIOS Date: 07/15/13 10:55:41 Ver: 04.06.05
          Processor: AMD FX(tm)-8350 Eight-Core Processor            (8 CPUs), ~4.0GHz
             Memory: 8192MB RAM
Available OS Memory: 8156MB RAM
          Page File: 3689MB used, 12659MB available
        Windows Dir: C:\Windows
    DirectX Version: DirectX 11
DX Setup Parameters: Not found
   User DPI Setting: Using System DPI
 System DPI Setting: 96 DPI (100 percent)
    DWM DPI Scaling: Disabled
     DxDiag Version: 6.03.9600.16384 64bit Unicode
DxDiag Notes
      Display Tab 1: The file aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL).  You may be able to get a WHQL logo'd driver from the hardware manufacturer.
      Display Tab 2: The file aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL).  You may be able to get a WHQL logo'd driver from the hardware manufacturer.
        Sound Tab 1: No problems found.
        Sound Tab 2: No problems found.
        Sound Tab 3: No problems found.
        Sound Tab 4: No problems found.
          Input Tab: No problems found.
DirectX Debug Levels
Direct3D:    0/4 (retail)
DirectDraw:  0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay:  0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow:  0/6 (retail)
Display Devices
          Card name: MSI Twin Frozr AMD Radeon R9 270x Series
       Manufacturer: Advanced Micro Devices, Inc.
          Chip type: AMD Radeon Graphics Processor (0x6810)
           DAC type: Internal DAC(400MHz)
        Device Type: Full Device
         Device Key: Enum\PCI\VEN_1002&DEV_6810&SUBSYS_30301462&REV_00
     Display Memory: 5870 MB
   Dedicated Memory: 2030 MB
      Shared Memory: 3840 MB
       Current Mode: 1920 x 1080 (32 bit) (60Hz)
       Monitor Name: Gateway FHX2300
      Monitor Model: FHX2300
         Monitor Id: GWY00BF
        Native Mode: 1920 x 1080(p) (60.000Hz)
        Output Type: HDMI
        Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
Driver File Version: 8.17.0010.1280 (English)
     Driver Version: 14.100.0.0
        DDI Version: 11.1
     Feature Levels: 11.1,11.0,10.1,10.0,9.3,9.2,9.1
       Driver Model: WDDM 1.3
Graphics Preemption: DMA
 Compute Preemption: DMA
           Miracast: Not Supported
Hybrid Graphics GPU: Not Supported
     Power P-states: Not Supported
  Driver Attributes: Final Retail
   Driver Date/Size: 4/15/2014 22:43:34, 1343272 bytes
        WHQL Logo'd: No
    WHQL Date Stamp: None
  Device Identifier: {D7B71EE2-2B50-11CF-D272-3A10BEC2C535}
          Vendor ID: 0x1002
          Device ID: 0x6810
          SubSys ID: 0x30301462
        Revision ID: 0x0000
 Driver Strong Name: oem80.inf:cb0ae41481af200e:ati2mtag_R575:14.100.0.0:pci\ven_1002&dev_6810
     Rank Of Driver: 00DA2001
I think something went wrong with the formatting on this post...
I just filtered through it.
AMD FX8350
16 Gb RAM no idea what freq
Gateway FHX2300 23" monitor
and some sort og Gigabyte mobo
