When i press the power button nothing happens, no fans start no lights. I've checked all the power cables. This morning i left it mining... now its dead. Only the 2 PCIE lights on the asus 280x are on. Does anyone have an idea what is causing the problem?
I pressed it for a sec and for like 20seconds. No beeps at all. I'm not sure if i've ever heard a beep from my mobo. If my psu is the problem would it be logical that the indicator lights on the asus gpu are on and green?
I am going to say that I agree with MisteryAngel in the idea that you may have fried your board. That is a lot of voltage to put into a not great VRM solution. That combined with the fact that the lights on your 280X are green, which generally means that they are getting power...if you have another PSU laying around, then I'd try that, but if not then don't go out and buy one. If you take the mobo out of the case, look on the back and see if you notice any obvious evidence of it being fried (brown streaks, charring, ect.).
Phenom's are pretty power hungry and mining uses a lot of power. All of those things combined could easily fry a board with an average power delivery system...
all motherbords have POST that said after looking at the guide for your mobo it appears the post is done with leds instead of the normal beep speaker. a feature they call dr.debug. but I don't own an asrock board so don't ask me how to use it some how you should be able to get codes like 0x53.
also yes the psu can still power some parts of a mobo even while broken.
My friend did not connect the pump of the cpu cooler. Thats why it ran at 80c :'(
Well SHIT, Ignore this: I tested my PSU in my friends pc his CPU became 80degrees celcius. I'ts an 3570k with a h100i. Normally it would be 42c. I guess it killed my VRM or CPU. It has 5 years warranty but I don't want another one :( I guess i'll be buying a 4670k+ASRock z87 extreme 3, but i wish to postpone this...
I would suggest testing another PSU on your rig first, I'm partial to Corsair's but that's me. Make should you only have to replace as little as you need to. Some motherboard will shut down to protect themselves. Not to give you false hope, just better to spend $80 and find out the rest still works, then spend $500+ and find out later it still worked. Just in case kinna thing.
Though if it were me I'd go $10 more and this way http://www.newegg.com/Product/Product.aspx?Item=N82E16817139055, but that's me. XFX is the only brand I've heard of that had a double life time warranty on any of their products, but that was on a video card and I think it was before they went AMD only. (I think, don't hold me to that.) Personally for a PSU, Enermax, Coolermaster, PC Power & Cooling, Corsair, and in a pinch Thermaltake are about all I'd use. Maybe seasonic and Fractal but I've never used any of those yet.
Since the PSU probably is not the problem... the overclock probably damaged my mobo, i'll send the mobo and cpu back to the retailer. Will upgrade to an I5 lateron.
I wanted to try crossfire on my new z87board and the 7950 seems to be the problem. When it's plugged in the pc does not start. I'll send my gigabyte 7950 to RMA. I'm still happy with my new I7......
