Any thoughts on the build? http://ca.pcpartpicker.com/p/WzZ6P6
Seems a bit pricy for the specs.
750 ti for $170 isn't worth it at all.
No need for an extra fan in this build.
yeah don't see the point of the extra fan. i assume you will be gaming on this pc? is there a fixed budget? Would recommend bumping up to a 270x (i'm not in the US so don't know about prices but performance wise should def be better than the 750ti). also think about putting more money into the PSU, one of the most important parts in your rig. aim for a 550/650 bronze corsair if price makes sense.
http://ca.pcpartpicker.com/p/KRpfRB
With the same price, I feel like this would be a bit better performance.
The FX 6300 is quite old chip, but for the price, it still performs pretty well compared to pricier i3's with only 2 physical cores (at least imo) and it can be overclocked for even better performance.
For the GPU, an R9 270 will be quite a bit faster than a GTX 750ti for the same price.
For the PSU, the cx430 should be more than enough (and if things haven't changed it should be quite good quality too).
$250 for cpu and mobo, might as well get an i5 at that point. The H81 mobo isn't quite the looker, but it will do the job just fine.
http://ca.pcpartpicker.com/p/BRVJqs
