My pc build
this is my first pc build
Specs:
CPU: Intel Core i7-3770 Ivy Bridge 3.4GHz (3.9GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I73770
GPU: geforce 210
RAM: G.SKILL Sniper Series 8GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-1600C9S-8GSR
PSU: Rosewill FORTRESS-750 750W Continuous @50°C, Intel Haswell Ready, 80 PLUS PLATINUM, ATX12V v2.31 & EPS12V v2.92, SLI/CrossFire Ready, Active PFC Power Supply
Mainboard: GIGABYTE GA-Z77X-UD3H LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
HDD / SSD:
Western Digital WD10EZEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive, Blue - OEM
OCZ Agility 2 OCZSSD2-2AGT40G.RF 2.5" 40GB SATA II MLC Internal Solid State Drive (SSD)
CPU Cooler: Default fan
Case: Antec Nine Hundred Black Steel ATX Mid Tower Computer Case with Upgraded USB 3.0
any ideas on upgrades? i know i need to upgrade my gfx card but other then that im thinking of the following items::
2014 Havit Magic Eagle 2400DPI X4 7D 6 Buttons Optical Usb Professional Gaming Mouse.
or
CM Storm Devastator - Blue LED Backlight Gaming Keyboard and Mouse Combo Bundle
could you not afford a gpu at the time, i mean good god, a 210!? I own one and the only thing I used it for was a media pc, then it had incurable overheating issues so I used it for a thermo electric cooler (peltier) experiment. but other wise your choices look good for parts focus more on spending on the gpu, your processor is solid (as long as you dont plan on overclocking it), you have a pretty good mix of HDD to SSD, just make sure you get whatever mouse fits your play style and hand size. whatever is the best value and price/performance, please PLEASE dont get a high end gpu (780ti/ r9 290x ) they are just a waste of money, the most i would ever spend on a gpu is 500 dollars and that is pushing it.
The gtx 770 have a nice price / performance. If you live outside america you could also consider the 280x, should be around the same price with similar performance as the gtx 770.
at the time i didnt have enough to get the gpu. so i used what i had in my old pc. im undecided on to get a gtx 780 or something else. im still learning a good amount about my options.
GTX 770, GTX 780.  That GTS 210 is probably weaker than the integrated on that i7 lol.
Larger SSD.  Try a 128 or 256GB Samsung 840 Evo or Kingston HyperX.
Mouse is purely personal.  I have a $15 E-3LUE Cobra II that works great.  You can find them on amazon.
