This is my first entire system build, I was sticking to a £800 budget (1300 USD). It will be used for editing, rendering as well as gaming.
i7 2700k - CPU
Arctic Cooling Freezer Xtreme Rev2 CPU Cooler
Asus P8Z77-V Motherboard
Corsair Vengence 1866mhz DDR3 8gb
Sapphire HD 7870
120GB Kingston HyperX 3K
1tb WD CB (I already had this)
Corsair CX750 Builder Series 80+ Bronze
Zelman Z11 Plus Case
Windows 8.
Thoughts?
Tyler
December 22, 2012, 7:47pm
3
I would personally go with Windows 7.
It is similar to my system. Why windows 8?
I didn't see the point in getting Windows 7. I personally don't find Windows 8 that bad when metro is disabled.
I would get a hyper 212 evo instead of that cooler and get a extra fan. So you can set up a push pull.
I was leaning towards that at the beginning, but I saw the one I bought for £15 and that kept it <800
This is what im going to be buying for my 2700k.
http://www.amazon.com/gp/product/B0045JCFLY/ref=ox_sc_act_title_1?ie=UTF8&smid=A23NVCSO4PYH3S
http://www.amazon.com/gp/product/B005O65JXI/ref=ox_sc_act_title_2?ie=UTF8&smid=ATVPDKIKX0DER
http://www.amazon.com/gp/product/B007RESGD0/ref=ox_sc_act_title_3?ie=UTF8&smid=ATVPDKIKX0DER
That's very similar to what I had in mind, but I needed it to be less than or equal to 800. And anyway I only plan to oc to around 4.
You can always wait until you have extra cash. Thats what i did am still using my stock heat sink.
http://teksyndicate.com/users/slay-english
Im am going to be ordering the stuff i posted above later this week.
Oxy
December 22, 2012, 8:10pm
15
I dislike the case, i hope you're using classic shell but i'm dissapointed that you bought the OS, that cooler is the definition of thermal mass i'm sure it'll take you far.
Oxy
December 22, 2012, 8:11pm
16
if you want to OC past 4 dont buy it. i have one and it's a fucking jet.
