So after years of building computers for friends/family, its my turn: and I want to go higher end.
I do some gaming, Starcraft 2, LOL, anything from Ubisoft (far cry/assassins creed/splinter cell/ghost recon), anything Valve (Portal/TF2/CS). I also do Linux, a lot.
Case:
-Fractal Design Arc Midi R2 Black USB3.0 Mid ATX Case
http://www.canadacomputers.com/product_info.php?cPath=6_112&item_id=057566
CPU/Processor:
-Intel i7 3820k (LGA2012)
-I think its the best value, great reviews, can overclock and my water cooling system should be more than enough.
Motherboard*
- MSI Big Bang-xpower
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813130626
OR
ASUS Rampage IV Extreme
http://www.newegg.ca/Product/Product.aspx?Item=N82E16813131802
-both ~$430, if anyone could recommend one or something else with 8 ram slots/ LGA2012 with good reviews in $400-$600 range
RAM
Going to start off with 4x8GB, upgrade as required, 2400 speed, was thinking G.Skill Ripjaw Z?
Graphics card*
-Need good Linux Support, I keep hearing Radeon is better, then I hear Nividia is better. Any thoughts? I am thinking higher end, without breaking the bank: like GTX680 or HD7970
Storage
I have plenty of HD's for storage, and a 120GB HD that I will install windows/programs on, will probably pick up a Kingston HyperX 480GB for games and larger programs.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820239047
Then some smaller stuff like fans (have some/buy some),cheap DVD drive (mine recently died), I already have 2 good monitors, keyboard (Steelseries 6gv2) and general peripherals (xbox controller)
Any recomendations/Help?
