Hi guys,
So I have an old h87 ITX Motherboard and it had a bent CPU socket pin, I bent it back very carefully and now I can't see where it it, so that means that it's bent back correctly coz it's blending with the other pins. But it still isn't working..
I tried with a Pentium g3258 and it wouldn't post or anything, apart from turn on the CPU fan.
When I tried my 4790k it was the same but this time the CPU fan wouldn't even spin!
Any ideas on what's up?
There is a green light in the motherboard that lights up when it's on and it is doing that, so it is getting proper power and some of the board is still definitely working.
My motherboard is a H87i-PLUS from Asus.
One other thing i'd like to point out is that this motherboard needs a BIOS update for use with these CPUs, but shouldn't it at least post and get into BIOS anyway? You don't even need components to get into BIOS right?
