My linux wish list (need help)
So I got my old laptop (Lenovo T510) which doesn't get as much usage as it did before and I was thinking replacing my Windows install with Linux as a mean to learn this new OS (I have some prior knowledge of Linux and the CLI but would like to be more serious about it). I tried couple of distros via virtualization: Mint, Ubuntu, ArchBang, Manjaro, Debian, CrunchBang and recently, on the recommendation of Zoltan, Sabayon which I really liked and chose as the one I would install.
But they're some things I liked from other distros that I didn't see in Sabayon and was wondering if I could easily get them. Also, they're some program/games which I have in windows that I would be very sad to lose. Here's a list of what I would like to have.
1) I really liked Crunchbang's implementation of Openbox and Conky. Can it be replicated in Sabayon?
2) Is there a way to have something similar to Aero Snap on windows (Windows Key + Left for docking left, +Up for maximize, etc.)
3) I would like to be able to play the following games: League of Legends, Hearthstone, World of Tanks (less important) and light games on my Steam library (ex: FTL). I'm also a part-time photographer and it would be great if I could run Lightroom 5 and Photoshop CS6. My CPU have VT-d enabled so  virtualization is an option here if the performance are right. Unfortunately, the video card on that laptop is a NVS3100M which is from Nvidia so no VGA pass trough I guess?
4) SolidWorks and MATLAB (if possible)
5) And I guess this is it for the moment.
So is it possible? Thanks in advance for the response.
1. You can put any WM on any distro - Conky runs on pretty much everything, too. You can easily install both OpenBox and Conky on Sabayon.
2. That depends on your WM/DE.
3. I had great success installing Steam via Wine, then installing whatever I wanted to from my Steam library within the Wine executable (I'm not a gamer, persay). If you must have Adobe (gross), there has been quite the following with the Wine users (http://appdb.winehq.org/objectManager.php?sClass=application&iId=5839).
4. Wine has had much success with both SolidWorks and MATLAB (http://appdb.winehq.org/objectManager.php?sClass=application&iId=318 and http://appdb.winehq.org/objectManager.php?sClass=application&iId=5839)
1. What brennan said. There is a vivid community of conkyrc's.
2. Yes you can on most DE's, you can assign the hotkeys you want, and the window manager handles all the snapping and tiling you want. Beware though that linux by default will move the windows over several virtual workspaces, so you might want to switch that off to autotile on the same workspace.
3. what brennan said. wine has just received an update, and is now even more powerful. with perfect configuration, it's been proven possible to run games faster in wine on linux than native on windows. there is a constant development going on on the state trackers for directx, and it's still evolving rapidly. Adobe lightroom and photoshop are very old school applications, they don't have a lot of advanced acceleration features like more modern applications, they run just fine in wine or in a windows virtual machine on linux.
4. what brennan said. You have to be aware of the fact though that there are many alternatives in linux to both matlab and solidworks. I guess if the linux native applications are good enough to design very complex things like the Eurofighter with, they are good enough for anyone. I'm giving the example of the Eurofighter because Dassault has developed it's own cross-platform, linux native DWG editor for instance, which is not FOSS because it is touched by some AutoCAD licensing, but it's still free to download and free for personal standalone use, and that's the software that is used to design the most modern space and aeronautical platforms with. Other companies do a similar thing for DWG's, or you can go entirely open source and install openCAD, which is a good program and a lot of people and companies use it, to the point where AutoDesk now offers most of its software for free on a lot of platforms and even as chromium plugins or android apps, whereas they used to be the pirate hunters par excellence before autoCAD became so big... advantages of open source applications include more features, more compatibility, integrated 3D printing support, and above all, better performance through a more modern compute back-end.
