It appears the front and rear USB 3 on my dual 4k KVM remain attached to port 1 even while another port is selected. This issue just started happening and I have reattached everything in the correct order multiple times. Is my KVM dead?
Probably not. There’s a hotkey that helps debug usb3 issues and you’ve probably hit that by mistake…it locks usb3 to one pc which is useful for debugging driver crashes.
Will have to get the key sequence to reset it in a bit.
Cool thanks that is very useful.
If you dont want to wait on him there should have been a manual that came with the kvm (Few pages) that has the key commands.
Yes it was listed in the quickstart guide under USB-Port rule left control 2x plus f7. Thanks guys for quick replies
