Hello I'd like to ask for help with overclocking my hd 7850.
I know a reasonable amount about overclocking and I have overclocked my previous gpu successfully however I've faced trouble when overclocking my vtx3d 2gb 7850. The issue is that when I try to set a higher mem or core clock I get a bsod, even if this value has been set from stock frequency to 1mhz higher I encounter this issue. At stock clock my card runs without issues at 1000mhz core and 1225 memory, I've also tried to overclock my card with multiple oc software including saphire Trixx, MSI afterburner, Asus gpu tweak so the software seemingly isn't a problem here? Also changing the voltage does not make a difference to the outcome as I bsod with or without increasing the voltage. Furthermore I don't see any artifacts or graphical glitches when I attempt to overclock the card for the short time before it gives me the bsod. I know that cooling also isn't an issue as at stock the card rarely hits 60 degrees unless its a very hot summers day were the highest I've seen is 65.
Any help would be fantastic! If you need more information then just let me know :).
Extra info:
Drivers tested with (amd ccc): 13.9, 13.12, 14.10
Pc specs:
motherboard: gigabyte 970a-ds3
cpu: amd 4170 @ stock speed (4.2ghz)
memory: 8gb ddr3 1600mhz crucial ballistix
case: CM storm enforcer
gpu itself: vtx3d radeon hd 7850 2gb version
