My graphics card fan died
So instead of paying for a new card, I decided to save a little money.
Case fan-15$
Zip ties-2$
Having it still work just as well as the stock cooler? Priceless.
With the same clocks i had before the fan failed, it stays right at the same temperature after running heaven benchmark for an hour straight.
http://farm6.staticflickr.com/5472/11527583003_8245bd0cf0_h.jpg
http://farm4.staticflickr.com/3734/11527581353_f5c6ca43c5_h.jpg
It's great that the temps are holding up. That's what matters the most. Maybe replace the thermal compound if you have any lying around to get even better temps ;)
Funny It's actually quieter than the stock cooler as well
Such a classic geto mod. I did this with a 9800 GTX but used a 4 pin fan so i could regulate the speed.
