My Gaming PC Build
Hello i first want to say thank you for the feedback to everyone i would like everyones input about the following parts for a good gaming computer
Parts:
Case: Thermaltake Chaser MK-1
CPU cooling: thermaltake water 2.0
CPU: intel i7 3770k
RAM: 16 gb  1600 gskill ripjaw
Video Card: sapphire amd radeon 6970 2gb
PSU: raidmax 630w
hard drive: 1 tb western digital 7200 rpm hard drive with a 128 gb os ssd
Motherboard:MSI Z68A-G43
Disc drive: asus cheap drive (dont really need anything better)
if it's a gaming rig as you say you should cut the cpu horse power and buy a i5 k instead. And with that money spend a little bit more on the graphics because thats what matters the most ! :)
Make sure the psu is a good quallity brand with 80+ certification you don't wanna blow up your system!
A 6970 is more expensive than a 7950 and performs worse. Get a 7950.
