GPU: XFX Radeon HD 7970 3GB DDR5 (Double Dissipation Edition)
I'm thinking about this build for my first gaming pc. The only thing I'm really worried about is that there won't be enough fan connectors on the motherboard for the case fans. I've heard that you have to connect the case fans to the power supply but I'm not sure what kind of connection I'd have to use.
I really appreciate any advice/criticisms you may have. But please don't be crude about it. Although I have to admit I've never met an unkind person on these forums... :D
i would avoid that power supply tbh, would go for a better brand (corsair, seasonic, xfx, and a few others)
for fans you can always get somthing like this http://www.ebay.com/itm/4-pin-Molex-M-to-3-pin-F-Fan-Adapter-Cable-NEW-/370723052243?pt=LH_DefaultDomain_0&hash=item5650d0dad3 and plus your case has a fan controller on it as well
If you are gaming you are not going to be using 16GB of ram, and I don't think you will notice the difference between 1600Mhz and 1866Mhz. If you are going to spend that much on a CPU cooler, I would either go liquid cooling, or the Noctua NH-D14 ( http://www.newegg.ca/Product/Product.aspx?Item=N82E16835608018&Tpk=noctua%20dh )
Also, that PSU worries me, I have never heard of that brand, and you won't use 750W unless you go for two GPUs (even then you probably won't use all of it) I would go for a Seasonic, Corsair, XFX, or NZXT. Other than that it looks like a really good build.
