My friend wants to upgrade his motherboard to go sli and his cpu is AMD, and I have no clue about AMD cpu's so will the cpu http://www.newegg.com/Product/Product.aspx?Item=N82E16819103774#spec work on this motherboard http://www.eclipsecomputers.com/product.aspx?code=MBG-M57SLI-S4&af=50 the ram, video card, etc... is compatible but im just not sure on the cpu. Any help is much appreciated, thanks
yep it will, The amd dual core has a socket AM2, and so does that motherboard. So its all good.
ok thanks for the help, im sure he will be happy to hear this
