Hey guys, I this is my first time building a pc,
I want to know about 5 benchmarking softwares.
Thank you so much
It sa science project
Thank you so much
And what drivers do I hav eto install thanks!
5 different benchmarking programs? Well you have AIDA 64, Unigene Heaven or Sanctuary, 3DMark Vantage, SuperPi and MSI Kombustor. Of all of these, I find that Kombustor is the easiest to interpret, and all the least conclusive. It is very good as a burn-in tool for your GPU and to test it for stable overclocks. Unigene powered benchmarks are very difficult for your GPU to render because of the high precision required, high levels of tessellation, real-time effects such as a live skybox, bloom, lighting effects, etc. This is designed to max out your GPU to test stability and cooling efficiency. AIDA 64 is primarily CPU testing and is used to test for the stability of overclocks on your CPU. This is not recommended for Ivy Bridge series processors as it pushes the voltages higher during testing and may cause permanent damage to the chip. For some reason, this has been remedied for Haswell. Because of this additional voltage, and the extreme CPU loads involved, this is the end-all for CPU burn-in and stress testing. 3DMark Vantage is very similar to Unigene Heaven or Sanctuary, but uses a different rendering engine. SuperPi is a single-threaded calculation tool to determine the efficiency and speed of your CPU's clock cycles. It uses one thread to calculate a certain number of digits of Pi, and the result is given as the amount of time required to do so. I will occasionally use any number of these tools, but I always have MSI Kombustor installed.
All of them. Seriously. I recommend downloading a program called Slim Drivers:
https://www.slimwareutilities.com/slimdrivers.php
It will find your necessary drivers with an astonishingly high rate of success, download them and install them. Unfortunately, you have to tell it to do so one at a time, but the process is painless enough.
Oh yeah one problem, I forgot to buy the cd reader and how do i install windows without it, i have a mac first time moving to the PC WORLD :D, so... if anyone can help me skype to at kevin2019170 thanks
