As the title says I am new here. Well after trolling the site for a while watching several build videos I have decided to go ahead and build my first gaming pc.
For the CPU I went with the fx-8350
Mobo : Asus Sabertooth 990fx R2.0 AM3+
RAM: Gskill Ripjaws X 8 gb for now
PSU: Corsair CX600M
Case: Corsair carbide 200R Black
GPU: going for the 670 or the 7970 ghz edition what do you guys think?
7970 ghz beats out 680's so unless you are playing a lot of nvidia optimized games it's the better choice I'd say. But yeah, it all looks good as far as your build goes.
Well, a gHz edition is simply factory overclocked. You could save money by getting a standard 7970 and overclocking the crap out of it. If you use Adobe products, however, a 670 would be fantatsic. Make sure to get a single 8GB stick of memory so that you have the possibility to upgrade to the max of 32GB later. Other than that, the build looks great!
The noticable difference is miniscule. If you want to cap out at 16GB of memory, that is fine, but if you want to use all that you can - i.e., 32GB, then you need 8GB sticks.
Implying windows and modern motherboards won't have issues running in single channel. I SHIGGIDY DIGGIDY. Unless you consider crashes and bluescreens miniscule.
The build looks really nice. I would go with 2X8 sticks of RAM for starters. I could be wrong, but I think Windows 7 Home Edition can only utilize 16GB of RAM anyway. I think you have to go to Pro to be able to use 32GB of RAM and just what would you be doing that would require that much RAM? Unless you plan on doing video editing with Adobe software then go with the 7970 GPU. Hope this is of some help.
I went a head and bought the parts, I put them together and so far so good posted fine and i am runing ubuntu for now going to install windows later today. For the GPU i decided to go for the 7970 regular as paying extra for a small boost is unjustifiable.
