My first pc!
Hi everyone!
Im a newcomer and if i dont know something please dont hate me!
So this will be my first (gaming) pc.I wold like to hear all youre toughts on the computer and all of your suggestions!Here are the specs:
processor (cpu):AMD vishera x8 FX-8350 4.0Ghz
video card (gpu):EVGA e-GeForce GTX660 SC Signature 2 3GB 192bit DDR5
motherboard:ASRock FM2A85X Extreme4-M, Micro ATX, AMD A85X, s.FM2, 4x DDR3
ram: DDR3 KIT 2X4GB 1600MHz, G Series, Adata
ssd:Adata 64GB, XPG SX900, SATA3, 2.5"
power supply:Corsair Builder Series CX430
case:SPIRE SP6012B or Delux DLC-MZ405 Gaming
This is all and i wold really apreciate if you rate this and or suggest something else! :)
Thanks in advance!
I'd get a bigger power supply 550w and a 7870 xt
Thanks for the advise about the power supply but what does 7870xt stands for ? video card mybe ?
That motherboard is socket fm2, an 8350 is not compatible. You need a AM3+ motherboard.
I would also recommend you get some better memory, rated at 1866 MHz or higher
A GIGABYTE GA-970A-UD3 or a msi 970a-g46  motherboard would be sufficient for this build
64gb really isn't enough... Get a normal 1tb HDD and get a AM3+ mobo like anarmypig said.
+1 i agree but I would suggest to also get a 128gb Kingston HyperX drive
I would also recommend an aftermarket cpu cooler, the ones AMD supply with their processors are trash. the prices on these can vary from $25 to $100 depending on how large of an overclock you want to be able to do.
$30, cooler master hyper 212 evo
$50, xigmatek dark kinight hawk edition
$100, corsair h100
if you choose to buy one of these, don't forget to watch Logans thermal paste video
+1 to everything anarmypig said
This build is a good start but you have a few flaws. First of all, your processor isn't compatible with your motherboard.
I would change the motherboard to the ASRock 970 Extreme3 AM3+ ($114.99)
I would get an EVGA GeForce GTX 670 2048MB GDDR5 instead of your 660 ($374.99)
A 64gb SSD is a joke IMO, get the same A-DATA XPG SX900 but get the 128GB variant ($114.99)
You definitely need a bigger power supply, go for a Corsair Enthusiast Series TX750M Modular 80+ Bronze PSU ($120.22)
I would also recommend a Fractal Design Define R4 case ($120.39)
IMO, these upgrades would greatly improve your build :)
Guys i forgot to tell you this has to be alittle cheap,because in my country this build+the monitor is about 1700 dolars!
I agree whit all on the motherboard ill get the same asrock AM3+ like anarmypig said or the gigabyte suggestion.
Also a better power supply really wold be good.Sorry to overlander 35 because that video card is too expencive :(
And after i get my pc i wold start saving money for the amazing coolers that anarmypig said! (from logans videos)
Thanks to all! :)
