I'm currently looking to build a PC and have pulled together some parts and others I think look pretty good. This is my first PC build and I want a very powerful and efficient gaming machine. I have about NZ $2,100 NZ to spend and this is what I have put together
CPU Cooler - NZXT HAVIK 140 CPU COOLER DUAL 140MM FAN
Hard Drive - OCZ Vertex 4 VTX4-25SAT3-128G 2.5" 128GB SATA III MLC Internal Solid State Drive
Hard Drive - Seagate Barracuda ST2000DM001 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive OEM
Graphics Card - Asus GTX 660 Ti DirectCU II 2GB GDDR5 PCI-E3.0 2xDVI HDMI DisplayPort GTX660 TI-DC2-2GD5 or Asus HD 7950 DirectCU II TOP 3GB DDR5 PCI-E 3.0 Video Card HDTV 2xDVI HDMI Displayport
Optical Drive - ASUS Black 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive Model BC-12B1ST/BLK/B/AS
Is this a good build for gaminng? and which graphics card should I use? Do I need anything else? Also I am not a pro when it comes to this so I am not sure if its all compatible or if these parts go together well. Any response, tips or help would be appreciated. Thanks alot
It is a powerful gaming system! Personally i would go for a 3570 and save $100, the difference between the two in gaming is very little at stock clocks.
http://www.anandtech.com/bench/Product/550?vs=647 Here is a bench between the 660Ti and the 7950, if you decide for a 3570 you can buy a much more powerful card like a 7970.
Here is a benchmark of the 7970 http://www.anandtech.com/bench/Product/508
I do not see a power supply on that list, did you forget to write it down or are you looking for recomendations?
A XFX 750w will do the job and give you plenty of power left over for future upgrades, Corsair HX 750 is also a wonderful power supply.Seasonic also makes wonderful powersupplies as well, as the Rosewill Capstone series. Take a look at the prices on those and post back what they are and we can pick one.
Holy heck $500 for a XFX!That is insanely high, which seasonic is it exactly? What's the model number? So far the HX750 seems like the best one, those prices are definitely high.
