My first PC build
So I'm going to be ordering the parts for my first PC build but I'm running into problems when it comes to buying a good power supply for a reasonable amount of money (around $150 at most).
I will be posting the parts which I'm certainly sticking with. Can anyone make a good suggestion?
Seagate Hybrid Drive ST2000DX001 2TB MLC/8GB 64MB Cache SATA 6.0Gb/s NCQ 3.5" Desktop SSHD
Crucial Ballistix Sport 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model BLS2KIT4G3D1609DS1S00
Corsair Carbide Series 500R Black Steel structure with molded ABS plastic accent pieces ATX Mid Tower Computer Case
ASUS Z87-PRO LGA 1150 Intel Z87 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
EVGA SuperClocked 02G-P4-2765-KR GeForce GTX 760 2GB 256-bit GDDR5 PCI Express 3.0 SLI Support w/ EVGA ACX Cooler Video Card
Intel Core i5-4670K Haswell 3.4GHz LGA 1150 84W Quad-Core Desktop Processor Intel HD Graphics BX80646I54670K
I'd probably go with something like this - http://www.amazon.com/dp/B00918MEZG/?tag=pcpapi-20
Then you could use the rest of the money you saved to buy a dedicated solid state drive and storage drive.
http://pcpartpicker.com/part/coolmax-power-supply-zu900b
same price
900w
80+ certified
much less chance of killing a 900w psu with that build
