My first pc build
trying to build  a gaming pc i choose all the parts let me know what you think are there good should i change anything or any suggestions
Motherboard msi ATX DDR3 1333 LGA 1150 Motherboards Z87-GD65 GAMING
Corsair Professional Series 860 Watt Digital ATX/EPS Modular 80 PLUS Platinum Power Supply AX860i
EVGA GeForce GTX 780 Ti Superclocked, 3GB, 3072MB,GDDR5 384bit Graphics Car
Corsair Hydro Series Extreme Performance Liquid CPU Cooler H100i
16GB G.Skill DDR3 PC3-19200 2400MHz Trident X Series CL10 (10-12-12-31) Dual Channel kit
Intel Core i7-4770K Quad-Core  Processor 3.5 GHZ 8 MB
Corsair Carbide Series Black 300R Windowed Computer Case
Samsung  840 Pro Series 2.5-Inch 512 SATA 6 0 gb Solid State Drive
HP ZR30w 30-inch S-IPS LCD Monitor
The only thing I think you are missing a big hdd for storage, the 512gb ssd will fill up quickly if you are going to install a lot of games. I have had my pc for about 7 weeks now and have filled about 800gb of the 1tb.
I am no expert on this but it might be worth asking someone who is but it may be worth getting 2 smaller sdd's to run them in raid 0 to get a bit more performance out of them but if one dies you loose all your data. I don't know if you would get much more performance out of them if you have 2 over 1.
thank you  yes i will be getting a Seagate Barracuda 3 TB HDD  and i have a 1 TB for back up
Looks pretty nice to me.  There are parts you could cheap out on and wouldn't affect gaming, though.
RAM 1600mhz and higher will be just fine for gaming.  Having higher clocked RAM really only helps when you're video rendering or using integrated graphics.
PSU is overkill for one GPU.  It'd be fine if you wanted to run two 780TI's in SLI.
thank you i plan to get another 780ti later next year. i got a good deal on the RAM thats why  great advise thanks a lot
