http://pcpartpicker.com/user/samo600006/saved/1tke
use gaming
ok i know it dosen't have a graphics card but im going to buy one later when i have a bit of mony and this is US currency. I want to future proof it so in 3 Years it wont be a piece of crap also can u recomend a graphics card. i am going to ad more ram and a cpu coler later
$750 increasing $25 a week
Do not get a i7 unless you are rendering, you can save 100 bucks by going with i5 3570k. For graphics you can go with a 7870 once you have enough.
ok i will keep that in mind
how much dose Hyper-Threading affect it
Affect rendering? If you are talking about rendering then H-T will make it a lot faster but if you are talking about gaming then it doesn't really do anything since games can't really take advantage of all the extra threads yet. :)
This is probably as good of a full system that you could expect to find for around $750
http://pcpartpicker.com/p/QS2L
i fit in a 7950, 2 tb of storage, and an FX-4300. Build this systam mayng. It'll play anything, at 1080p and highest settings, without a hitch.
if you gonne do mainly gaming, then i would go with an AMD setup, with an 7870XT or 7950 gpu. FX6300 cpu or better.
http://pcpartpicker.com/p/QSuZ
Just grab this, then upgrade it when you feel it be necessary.
It's better to just buy a build and upgrade when needed than sit around waiting foreva. Trust me.
can I O-C this i dont know much abought AMD
http://pcpartpicker.com/p/QSIa
