My first PC build please help!
Guys Im thinkin to build a budget gaming PC and I'm stuck b/w lot of questions so the first one is CPU: intel i3 3220 or AMD 3.4 GHz AM3 Phenom II 965 Processor I'm not able to decide and other is the GPU : nvidia gtx 650ti or sapphire 7770? And the next one is I don't know anything about mother boards if you could give me some suggestion it'd be really great and what does ddr2 ddr3 and gddr5 mean? I know they are a lot of question but plz help me  and if you could tell me any steps or suggestions it would be great
In ddr2,ddr3 and gddr5 what ram should I buy for my PC
What's your budget?
my budget is 600$
http://pcpartpicker.com/user/armypig/saved/1pkI
What do you think of this?
OMG thanks a ton dude this is just the way I wanted just fwe adjustments and I can afford it :D #mademyday thanks a ton
No HDD...
woops, yep I forgot the hdd. You could just cannibalize the one out of your old machine, or you could get this.
http://pcpartpicker.com/user/armypig/saved/1pla
http://pcpartpicker.com/p/Nv4P
http://pcpartpicker.com/p/NvfS
CPU: AMD Phenom II X4 965 Black 3.4GHz Quad-Core Processor ($92.99 @ NCIX US)
Motherboard: ASRock 960GM/U3S3 FX Micro ATX AM3+ Motherboard ($60.97 @ Newegg)
Memory: Crucial Ballistix sport 8GB (2 x 4GB) DDR3-1600 Memory ($54.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($74.99 @ Newegg)
Storage: A-Data Premier Pro SP600 64GB 2.5" Solid State Disk ($54.99 @ Newegg)
Video Card: Asus Radeon HD 7850 1GB Video Card ($149.99 @ Amazon)
Case: Fractal Design Core 1000 MicroATX Mini Tower Case ($37.99 @ Amazon)
Power Supply: Corsair Builder 600W 80 PLUS Bronze Certified ATX12V Power Supply ($49.99 @ Newegg)
Optical Drive: LG GH24NS95 DVD/CD Writer ($17.99 @ Newegg)
Total: $587.89
i see that your questions have been answered but i just whanted to say that without a doubt the Phenom
is much much better than the i3s from intel.A phenom x4 965 compared 2 the i5 2500k is confusing tough.the 2500k performs better around 20%-30% more but is for 120 more so its a nobrainer :D
thanx for the replies guys but I also wanted to know if I could take out the cooler and even reduce the motherboard's price?
if you whant to reduce the price on the motherboard use coopermans motherboard of choice http://pcpartpicker.com/p/NvfS
And yes you can use the stock cooler to save you 30$ but i wold recommend getting an aftermarket cooler once youve got the money! cooler master hyper 212 evo is the best for budget builders!
Thanx dude ^_^
Oh and another thing i forgot to mention that coopermans motherboard of choise is micro ATX,that means its very small if you dont know!If you dont whant a micro atx motherboard i suggest this http://www.newegg.com/Product/Product.aspx?Item=N82E16813157319R because Logan reviewed it in 1 of his videos.Alsio this motherboard is on sale for now if it runs out get this http://www.newegg.com/Product/Product.aspx?Item=N82E16813157323&Tpk=asrock%20960%20GM&IsVirtualParent=1.
Now for the RAM just go to the RAM discusions and ask there.
And last,can you tell me what is your final build parts that you have chosen ? I really dont whant to mess your build up!
Yeah sure i'll tell you I haven't decided it yet abut when I do I'll definitely tell you :)
Wow so quick :D
I will be waiting!
My PC build anarmypig and dark soldier help a lot
sorry to put all the small this too but for now this is my build I'd love to heard some suggestions :D
and the Prices are according to the son line store where I buy them I live in India so the prices are somewhat high and case is omitted coz I'll buy a cheap one :p
Intel i3 3220 - $144.02
Gigabyte NVIDIA GeForce GTX 660 2GB GDDR5 - $314.64
ASrock 970 extreme 4 motherboard - $139.24
corsair vs550 550 watt PSU - $64.4
Seagate barracuda 1 TB - $84.28
Samsung 20" LED - $150
Iball amazer - 7.44
HP internal optical drive - 28.26
                       TOTAL = 933.28
Totally over my budget but I guess I'll buy it :(
:D
Lol the placements of the things got screwed up
*online
