http://pcpartpicker.com/user/adamburns/saved/4wYq
I would like to play games on really high settings. Please suggest parts that i can swap for the ones i have in this build that will keeps the performance the same and can you suggest monitors,mice,keyboards,headset.
I would like to keep the budget at about $1500.
the build is good, but you would get more performance out of an FX 8350 over that version of the i5. also look into win7 over 8. windows 7 is better overall for plug and play type games without having to fiddle with all the settings to get windows working and looking the way it always should be. and if you wanted to run max settings in most games go for a 780 SC. it would keep the price around the same overall with maybe +50$
http://pcpartpicker.com/p/3BBhC
if you ARE going with that CPU, here's a build with $178 shaved off, no performance loss at all, and an extra 4GB of memory...
Do you want an AMD option? or would you rather have a 4670k build at your same price range?
I think the 780 is pretty unnecessary, and I own one... a really good one :P... a 770's all you'll need at 1080p... unless you're running multiple monitors
This rig will run games on high settings, my friend get solid 50-60fps on Battlefield 4 at high/ultra with his 770, and hes running a FX-6300 AMD 6-core processor @4.1ghz. So this rig will be able to outdo that.
The only thing I can recommend would be to go for an AMD processor based system as it would be cheaper, and to upgrade from 1333mhz to 1600mhz ram (But I doubt this would make a noticeable difference.). If you saved some cash on making this an AMD based system you could grab a better monitor, like a 1440p or 144hrz monitor, as this would actually cause there to be a noticeable difference.
For 1500$ including peripherals, this would be a beast setup that could run games with 1080p high/ultra settings no problem.
http://pcpartpicker.com/p/3BQs4
Hope I helped :)
Pretty good. I tried to get it under budget.
http://pcpartpicker.com/p/3ClQe
YOU WANT BLUE ?? I GIVE YOU BLUE !!!
lol
PCPartPicker part list: http://pcpartpicker.com/p/3Czvv
CPU: Intel Core i5-4670K 3.4GHz Quad-Core Processor ($234.99 @ Amazon)
CPU Cooler: Phanteks PH-TC12DX_BL 68.5 CFM CPU Cooler ($59.99 @ Amazon)
Motherboard: MSI Z87-G55 ATX LGA1150 Motherboard ($116.99 @ Amazon)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1866 Memory ($78.99 @ Newegg)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Disk ($84.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($56.99 @ NCIX US)
Video Card: Sapphire Radeon R9 280X 3GB Vapor-X Video Card ($335.91 @ Newegg)
Case: Fractal Design Arc Midi R2 (Black) ATX Mid Tower Case ($99.99 @ NCIX US)
Power Supply: XFX ProSeries 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($99.99 @ NCIX US)
Monitor: Asus VX238H 23.0" Monitor ($139.99 @ Micro Center)
Keyboard: Logitech G105 Wired Gaming Keyboard ($41.98 @ Newegg)
Mouse: SteelSeries 62016 Wired Optical Mouse ($36.35 @ NCIX US)
Headphones: SteelSeries Siberia v2 Headset ($84.54 @ Amazon)
Total: $1471.69
(Prices include shipping, taxes, and discounts when available.)
(Generated by PCPartPicker 2014-05-02 12:42 EDT-0400)
Under the budget
Sir, I think you're in the wrong thread.
https://teksyndicate.com/forum/build-pc/thinking-building-1200-pc/177180
