My first Mini-ITX build
Hey folks, first post.
I'm putting together my first Mini-ITX build, here's the build so far, I intend to buy CPU and GPU used, so any alternatives that would preform better would be well received,  I've put my rough budget for each required component at the end of each,  cheers.
CPU - Intel i3 4130 ( I already have the motherboard so must be socket 1150) - Budget £60 - £70
CPU Cooler - Arctic cooling alpine 11 GT - Budget £10 - £15
GPU - Nvidia Gigabyte GTX 750ti - Budget £100
Motherboard - MSi B85i ( Already owned)
Memory - 8GB (2 x 4Gb) HyperX Fury @ 1866Mhz - Budget £60ish
PSU - Corsair CX 430 - Budget £40 - £50
Case - BitFenix Prodigy Mini ITX (original i know :p)
Storage - Kingston 60GB SSD & 1TB WD Blue
Cheers for any comments offered.
S.K.
Prodigy is really big for this size.  Try a Cooler Master Elite 110.
Stock Intel cooler should also work just fine.
Also, what are you planning to do with this build?
Thanks for the reply.  I was considering the Elite, I do like it, but this is a mid range gaming rig for my partner, and she likes the white prodigy, so there we go.  She mainly plays Sims 4 / Sim city with the occasional action adventure (tomb raider etc)  the only reason I'm changing the cooler is purely cosmetic as it has white fan blades, shallow as that is :)
