Im new to pc gaming and this website. I also have no idea which parts can fit in what and work together i have some knowledge of good cpu's and gpu's from logans build videos but i would like some help with a build i have about $1000 but i need the good computer, monitor, keyboard, mouse, and operating system. If someone could suggest some things or maybe help me understand what things fit what i would really appreciate it
i would like to be able to play battlefield 3 all the call of duties maybe some racing games like nfs, and also for mmorpg like runescape and i will be doing some video editing like taking cod gameplay and adding music and things like that. I will be just having it in my room
Keyboard and mouse and monitor are so subjective. One person could love the fuck out of a keyboard and someone else would hate it. Same goes for mouse and monitors. There's like no way to objectively benchmark keyboard and mouse.
Monitors are down to preference. Image quality vs gaming response time. I prefer IPS or PLS panels over TN, some will call me an idiot, some will agree with my opinion.
Here's an Intel system that I put together that just barely misses the mark. If you're willing to pirate your OS then you could definitely get the computer without compromising much.
I'm sure there could be an AMD system that can fit the budget.
You're probably going to be looking at an AMD system with a (much) slower GPU if you still want to include monitor/keyboard/mouse in your $1000 budget. My example system comes with a randomly selected cheapest 1080p LCD, a cheapish Logitech washable keyboard because those are neat as fuck, and a Steelseries Sensei RAW mouse.
i could always just use my flat screen tv as the monitor and im sure i could squeeze together another 50 for a cheap keyboard and mouse till i can get some more money, is the intel going to be a lot faster. is it worth the extra money?
Will you notice it? Probably not. Definitely not during gaming. Maybe during recording your gaming.
Since you're going to do video gameplay I'm going to suggest that you get a third harddrive so add another one of those 1TB Seagates to the system so you can use it as a dedicated recording drive so you get maximum FPS while recording your fragging sessions.
The Intel option is significantly better, yes. But the Amd system will still perform amazingly well
http://www.anandtech.com/bench/Product/699?vs=701 Here is a comparison between the 2 CPUs, and you can clearly see that the i5 is a lot better.
If you're going to do rendering and i think video editing goes with it as well; i would recommend going with a Nvidia GPU because of CUDA cores or whatever it's called (I'm kind of new to that area).
And also an AMD CPU is compatible with a Nvidia GPU, So if you're going to be editing, rendering etc, but don't have the money for the i5 you could go with the 6300 and a Nvidia card. There is also room for upgrades if you're going with the AMD option. I think the 8350 is the highest end CPU using the Am3+ chipset atm (Correct me if i'm wrong).
