My first gaming pc build
Hi there,
I'm going to build a PC here in the Netherlands and I want you opinion about this PC.
I'll use it for gaming and I'll not upgrade soon
I'll buy those parts on the 25/08/2013 so I need to make the last decisions
So here is my build:
cpu - AMD FX 6300/6300
motherboard - Gigabyte 990FXA-UD3
Graphics card - MSI TF III GTX 660 OC
Case - CM storm scout 2 advanced
ram - G.SKILL ripjaws 8gb 2x4 GB 1600MHz
psu - Corsair cx600m
Hard drive - WD blue 1TB
What do you think about the build
My budget around the same as the parts cost here
And here everything is expensive here :(
Regards,
Hello. I think this is a good build for gaming. You can upgrade it will an 83xx processor at a later time, or a better GPU. Good to have those upgrade options!
I would replace the power supply with an XFX 550W. It is higher quality, and probably a little bit cheaper. If you can't find that PSU, the CX is fine.
change the Gigabyte board to an Asus board, I've had way too much trouble with gigabyte, and I think they're just a cheap company with a big face honestly, I mean really I don't trust a company that has enough gall to put 2 power phases on a Mobo and sell it claiming any kind of quality.
look for a 1866 CAS 9 kit, you can sometimes get them for a few bucks more than a 1600 kit
Personal opinion, get a worse case (you could get away with a HAF 912) and get a fx 83xx CPU like the guy above says.
yep a case is cheaper to upgrade/replace than a CPU is
well i don't think i'll downgrade the case as it will be on the desk in my room and i go to alot of lan partys
and my color theme is red black so that why i did not get a asus ....... EVO
trust me, you'll rather have a working PC than a red PC, if you are than worrided about the scheme you can get their ROG line or Sabertooth and paint the thermal armor
That is true but i heave seen no bad teview about the high end series + the gigabyte has more pci x16 slots
so can you give me more reasons to go with asus?
outstanding quality assurance and testing, as well as the quality of the components that they choose, why buy a high end Gigabyte board with mediocre components when you can get Asus which has high quality across the board, what would you use the second slot for? single slot solutions are better than dual cards, you should only use two cards if you are given one for free or if you have multi monitors or 1440p+
"...get Asus which has high quality across the board..." I see what you did there ;)
Well i'll use the extra slots for sli because i heave 3 monitors + 2 soundcards. I'll think about the asus motherboad they give me good futures. But the price is 40 euro more then the gigabyte one so i need to lower some things :(
i live in the netherland too and i have a simular build except i have a 8350  but i think its fine
btw buy your stuff at mycom they have great warrenty
