- COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
- HGST HDS721050CLA362 (0F10381) 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
- EVGA 01G-P4-2650-KR GeForce GTX 650 1GB 128-bit GDDR5 PCI Express 3.0 x16 HDCP Ready Video Card
- Antec NEO ECO 520C 520W Continuous Power ATX12V v2.3 / EPS12V 80 PLUS Certified Active PFC Power Supply
- ASRock B75M-DGS LGA 1155 Intel B75 SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
- Intel Pentium G2120 Ivy Bridge 3.1GHz LGA 1155 Dual-Core Desktop Processor BX80637G2120
- Microsoft Windows 7 Home Premium SP1 64-bit
- 2-COOLER MASTER Megaflow 200 R4-LUS-07AB-GP 200mm Blue LED Case cooler
- COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU CORSAIR Vengeance LP 8GB 240-Pin DDR3 SDRAM DDR3 1600
- LG 24X DVD Burner - Bare Drive Black SATA Model
- so tell me what u think i have never bulit a computer before wondering if theres anything i should change? tips on buliding would be good also
I guess it's good. It really depends on what you're doing and what you're budget is. If you're gaming, knowing what games you play can help as well.
im just trying to bulid a good gaming pc for under 700 bucks and thats what i hav came up with so far
I don't think you really need that CM Hyper 212, the stock cooler should be fine
http://pcpartpicker.com/p/EeGb
Here.
Your build was... okay. When I saw your budget was 700, and that you were planning on a pentium and a 650, I shuddered a little. I think the computer I put together will really blow your original build away. Definitely at gaming, and it came in at just under 700.
If you really are interested in buying Windows instead of "getting" it.. First of all, I respect you. And secondly, http://www.missionsofts.com/microsoft-windows-7-home-premium-sp1-64-bit-oem-dell/
Cheap, and it works like a charm. That would make your final cost about 760. SO what can you do? Bump the 6300 to a 6100 for starters, and then bump the extreme 4 to an extreme 3. You can go with a cheaper GPU, but a gaming machine is the place to get the best gpu possible.
Don't get a 650; it is a very weak card that is overpriced. Instead, get a 7870 XT like Toast recommended, or at least a 7870. 7850s are good budget cards, as well.
I've owned a 650 2gb edition in the past, and let me put it this way... I like my 5850 more, and it's way older...
I wish I had the money for a 7870xt.
ok thanks alot ill play around with your build and post what i come up with
