Hey. This is my first time on this site and first time building a PC. I would like to use the PC for gaming and maybe video editing.
I spent some time searching the forum and other places to gather information. This is what I came up with http://pcpartpicker.com/p/FnZgQ7
I would appreciate any feedback you can give. I would like to keep the build under $800 if you have any suggestions for improvements. Thanks.
Your build's a bit weak in the video card department.
http://pcpartpicker.com/p/WwwGnQ
If you really want an SSD, you can probably get a FX-6300, and grab a 120GB SSD along with the 1TB hard drive.
Zavar
3
Change the motherboard back to the M5A99X EVO r2.0 and it's much better.
Thanks for the suggestions. I'll be sure to incorporate them in the build.
Also if anyone could suggest a decent low budget wireless network adapter it would be much appreciated.
Not sure what "low budget is", but this should work just fine.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166082&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3938566&SID=
