My First Build
I'm new to building a pc, but i need a powerful pc for gaming/editing/rendering.
I need to know if the build i'm going for is a good build or not.
All Criticism Welcome.
Build here:
http://pcpartpicker.com/p/2SMxK
I want a 80+ platinum psu, so dont suggest any psu's that aren't.
Thanks -Aeolus4444
I'd stick with that seasonic unit that is in your build list. That right there is PSU porn.
The only things i would change are the motherboard to a 990fx pro because it would do the same job for less, maybe just get 16gbs of ram instead of 32gbs and get a case that has usb 3.0 on it unlike the one you chose which doesn't have a usb 3.0 headers on it.
The case has 3.0 headers, that's just a glitch with pc part picker, but the rest of what you said ill look into. thanks
The 990FX looks very nice, ill probably switch to that one. The reason i chose 32 GB was because it was on sale when I put together this build, but now 16 GB is probably better. Thanks again you really helped me out.
Looks pretty good.  I gree with mcwopppersnaggy about the Asus M5A99FX Pro R2.0, and perhaps lowering the RAM to 16 gigs if you need to save some money.
