I am coming from console so I am into to console games plus minecraft, cube world etc. Not looking to overclock straight away. Mainly used for gaming.
This is what I was planning
CPU: Amd Athlon x4 760k
GPU: Asus 7790 direct CU 2 OC
Motherboard: Gigabyte GA-F2A85XN-WIFI
RAM: Adata Gaming Xpg Series 8GB
Case: BitFenix Prodigy
PSU: Aerocool gt-500 sg
Hard Drive: WD Blue 500gb
I am worrying if my psu will fit in the case I have picked. If there is anything you would add or change please suggest them. Hope you can help
Price £500-£550 including os
First off that motherboard is NOT compatible with that cpu THEY WILL NOT WORK TOGETHER. And I dont think the PSU is 80+ which is not good.
Here is what I would Build with that Budget.
CPU: AMD FX-6300...............................................................................................................120$
GPU:Sapphire Radon Vapor-X HD-7950 OC.........................................................................278$
Motherboard: MSI computer Corp. Soket AM3+ AMD 970 DDR3 SATA3 and USB 3.0............80$
RAM.: Kingston hyper x blu 8GB.............................................................................................70$
Case:NZXT Source 210...........................................................................................................40$
PSU: Corsair Builder Series CX 50 watt...................................................................................50$
Hard Drive:WD Blue 500gb.....................................................................................................60$
Total.......................................................................................................................................700$ or £430
That leaves you room for an os and a better case and/or storage. Please ask any questions!
Get this, but with a different HDD:
WD Blue 1TB 7200rpm.
The motherboard is compatible (http://uk.gigabyte.com/products/product-page.aspx?pid=4611#ov) and the power supply is 80+ gold but thanks for the other suggestions I will take it into account.
Sorry my bad I think it will work. To answer your original question I think that power supply will fit.
do you really need the bitfenix case? you can fit better parts if you get a mid tower case.
This build includes the Bitfenix case:
http://uk.pcpartpicker.com/p/1K6HK
This build is without the Bitfenix case, i would recommend this build as you're getting more for your money! If you cant squeeze that extra £15 then let me know and i will slim the build to match your budget!
http://uk.pcpartpicker.com/p/1K6MI
