Here is the Gaming PC I plan on building in a month. If there is anything you see that can be improved upon without raising the price significantly or that is more compatible please let me know.
CPU AMD FX-9370 4.4GHz 8-Core $219.99
CPU Cooler Corsair H100i 77.0 CFM Liquid $99.99
Motherboard Asus Crosshair V Formula-Z ATX AM3+ $224.99
Memory Mushkin Blackline 16GB (4 x 4GB) DDR3-2133 $155.00
Storage Samsung 840 Pro Series 256GB 2.5" SSD $203.29
Toshiba 3TB 3.5" 7200RPM $99.99
Video Card Sapphire Radeon R9 280X 3GB $398.98
Case Fractal Design Define XL R2 (Black Pearl) ATX Full Tower $129.99
Power Supply XFX 750W ATX12V / EPS12V $124.76
Optical Drive Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer $19.98
Operating System Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) $89.98
If you go with the H100i you will need to replace the included fans unless you enjoy noise coming from your rig. That will add 40.00 to the price tag. I have an H100i and wish that I never bought it. You will get better performance and cooler temperatures without any noise from the noctua NH-D14 at 1/2 the price.
You may also want to consider windows 8.1 instead of 7.
This build is basically the same, but I changed a few parts and added another SSD as a windows/programs boot drive. Use your big SSD as a dedicated game drive..
http://pcpartpicker.com/p/3pd4s
This build is:
Cheaper
faster (games and OS are on different dedicated drives for faster operation)
easier to overclock (2 ram modules are more stable than 4)
more reliable for data (less usage per drive)
has windows 8.1 (also faster than 7) you can get start as back to get the windows 7 usabilty
You lose nothing with this build other than maybe more data on the HDD I chose.. but I just seagate drives better than toshiba....
Anyway, I hope you like this build
**** Edit. get this by far http://pcpartpicker.com/p/3pqjL
You could just get an 8320 and OC, the 9370 is just an 8320/8350 binned with a higher clock. You can save a lot of money by getting an 8320, a decent cooler and overclocking it to 4.4GHz.The option is up to you though
If that's the case then I guess its alright to get 9370 if your willing to spend the money. Just know that keeping temps low on that chip will be difficult especially when you start overclocking
The gpu in my build is almost identical. Its just a different manufacturer. Its a little cheaper as a result. The manufacturer is still very good, don't worry.
If you are gaming at 1920x1080, the 2GB version of the card will perform just as well as the 4GB version. RAM helps with resolution, but not much else.
