My first Build ever
Hey guys,
I plan to build my first custom pc and I have done tones of researches. Now I have got gathered all my components together and am all sick off the numbers and information from all the reviews I have watched. The last step before I get to actually buying all the stuff is to ask you to check on my parts. Just to be sure I dont spend all my money on some crap...
Intel Core i5-3570K
ASRock Z77 Extreme4 Sockel 1155 ATX
MSI GeForce N660 TF 2GD5/OC 2GB DDR5
G.Skill Ripjaws X 8GB DDR3 Kit
Corsair Builder Series CX600 600 Watt ATX 2.3
Is the GPU bottlenecking the rest of the system? Is the power supply going to provide enough energy? Will I be able to play games like BF3, Crisis with maxed out setting? I really appreciate for all your help. I just worry I might do something wrong. (=
PS.: I REALLY apologize for my English... I'm from Austria.. not Australien.. ;-)
Buy Everything seems perfectly fine to me. I'd advise you to go for a 7870 however as it usually performs a little better than the 660 and costs pretty much the same. You should be able to max just about any game with both of them and at a playable rate :)
