Finished building my fist build and on startup I see the motherboard splash page. On the bottom of the splash page I noticed "CMOS failed. Press DEL to enter setup"
After a few seconds the screen switches and I get a black screen telling me to select a bootable hard drive
What SHOULD I see? do I need to send my mobo back?
Also note that I do not have an instillation disk yet. I'm waiting on it.
It means, find a section in your motherboard manual (the book you got with your motherboard) called either clearing the CMOS or clearing the BIOS, and follow its instructions. If this fails to fix your problem, then send your motherboard back.
The message means that either your CMOS is corrupt or that your CMOS battery is dead.
