http://secure.newegg.com/WishList/PublicWishDetail.aspx?Source=MSWD&WishListNumber=20388105
did i do ok.
thanks gigabuster.exe he help me alot with this rig
did i do ok.
personaly i would change the AMD proccessor to a i5 3570k or a 2500k but thats money and money doesnt grow on trees. so if you want amd spend maybe 20-30 more on the FX series should see a bit more of a performance increase also a little bit of future proofing. but that GPU will run nice and the rest seems to be spot on :)
good luck building :D
I agree with woolanator get an i5 3570k because there's no price difference between 3570k and 2500k and the 3570k is just a teeny tiny bit better :)
um this build is done people
But you asked for our opinions??
