My final list of my parts to buy
Heres the list
Western Digital Caviar Black WD1002FAEX 1TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Mushkin Enhanced Redline 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model 997008
ADATA XPG SX900 ASX900S3-128GM-C 2.5" 128GB SATA III MLC Internal Solid State Drive (SSD)
RAIDMAX HYBRID 2 RX-630SS 630W ATX12V V2.2/ EPS12V SLI Ready CrossFire Ready Modular Power Supply, New Version with Build-in LED Fan On/Off Switch
HIS H787F2G2M Radeon HD 7870 GHz Edition 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
COOLER MASTER SickleFlow 120 R4-L2R-20AG-R2 120mm Silent operation Green LED case fan
Rosewill RFA-120-RL 120mm 4 Red LEDs LED Case Fan
ASUS M5A97 R2.0 AM3+ AMD 970 SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
AMD Phenom II X4 965 Black Edition Deneb 3.4GHz Socket AM3 125W Quad-Core Processor HDZ965FBGMBOX
LITE-ON DVD Burner - Bulk 24X DVD+R 8X DVD+RW 12X DVD+R DL 24X DVD-R 6X DVD-RW 16X DVD-ROM 48X CD-R 32X CD-RW 48X CD-ROM Black SATA Model iHAS124-04 - OEM
Rosewill REDBONE U3 Black SECC Steel USB 3.0, eSATA, 3x 120mm Fans Mid Tower Computer Case
I would highly NOT recommend getting a raidmax PSU and if you aren't going to overclock the 965 then its not worth getting, what is your budget and I'll whip up something a lot nicer for the price
any would do just give me a good psu
could you give me a system budget?
um 80$ or lower foe the psu this list i have now i've already got the motherboard in the mail CPu is at the house & case is too with the dvd drive so im not willing to send that stuff back you said the psu is not a good idea just give me 1 that will work with my list
ok this 1 ok
http://www.newegg.com/Product/Product.aspx?Item=N82E16817152042
I would go with either one of these:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817116014
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096
changed going with the
CORSAIR HX Series HX750 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
hey im set on this
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
