My fastest system so far!
Main components
  1. i7 3930k @4.9GHz 1.39-1.4v
  2. G.Skill Ripjaws 1866 9-10-9-24 T1 16gb quadchannel
  3. Sapphire 290x @ 1200/1500
  4. Rampage IV Formula
  5. EVGA Supernova 1000 G2
  6. D-Frame orange case.
Watercooling components
  1. Phobya Nova 1080 Extreme radiator.
  2. MCP35x water pump.
  3. EK GPU and CPU blocks ( NO NICKEL! )
  4. CLU (coollaboratory liquid ultra) on the CPU and GPU. And Fujipoly thermal pads on the GPU.
The picture is horrible i know, im sorry. And yea the pump is getting enough water its not running dry even though i laid the pc down on its side. Ghettoing the pump to the res like that is actually very effective and easy way to mount a pump!
Tell me what you think, and what improvements i can do.
D-plugs are great ways to combine the pump and res - it's what I do!
First of all, I would switch the two tubes coming out of your pump/res, so that they aren't crossing. Purely aesthetic, but will look a lot cleaner.
Sleeving - sleeve those cables, and get a cubic shit ton of cable ties or velcro strips to clean them up.
Other than that, the build just needs some better pictures.
Looks good, mate.
Thanks for the input. About the tubes for the pump/res. I was told to have the pump pump the water directly into the blocks instead of through the rad THEN into the blocks. Does it actually make a difference?
WOW, looks great. i commend you for actually posting an ACTUAL build and it being a really good one.
that's a great overclock on the cpu and 290x too. cheers.
Thank you :), this is my first REAL watercooling build. Did a ton of research and asking around. Turned out great :).
Really, it doesn't matter much. Loop order, aside from res above pump, makes no difference in performance.
Run some benchmarks pl0x. Just to see how it stacks up. Very nice build.
How bout a few pics?
Oh.. Page didn’t load the pic, sorry.
I have a few 7970 benches with my 3930k before i got the case and made my loop not so ghetto.
http://www.3dmark.com/fs/1005312
Currently the fastest single 7970 on 3dmark FS atm :)
I didnt really bench my 290x as its not golden like my 7970. So i honestly dont see the point in benching it.
Fixed the pump like i was adviced to do :)
