i haven’t got everything posted to github yet but here is the jist
I asked claude to sum up what i had been doing on a pico controller and leave the controller out of it for a post. below is what follows. that i shamefully didn’t proof read well enough at all.
the basic concept is the same but idk where it came up w/ alot of its claims.
idea is to use a cached/fixed point combo to get around not having an FP unit but save the rounding till you have to , so you can use it for accumulators and the like w/o rounding it to fit till done.
My apologies for the overly self-fellating claims made my on by behalf by the robot population under my supposed watch.
Detached Point Arithmetic (DPA)
Eliminating Rounding Errors Through Integer Computation
Author: Patrick Bryant
Organization: Pedantic Research Limited
Date: July 2025
License: Public Domain - Free for all uses
Abstract
Detached Point Arithmetic (DPA) is a method of performing exact numerical computations by separating integer mantissas from their point positions. Unlike IEEE-754 floating-point arithmetic, DPA performs all operations using integer arithmetic, deferring rounding until final output. This paper presents the complete theory and implementation, released freely to advance the field of numerical computation.
“Sometimes the best discoveries are the simplest ones. This is my contribution to a world that computes without compromise.” - Patrick Bryant
Table of Contents
- Introduction
- The Problem
- The DPA Solution
- Mathematical Foundation
- Implementation
- Real-World Impact
- Performance Analysis
- Future Directions
- Acknowledgments
Introduction
Every floating-point operation rounds. Every rounding introduces error. Every error compounds. This has been accepted as inevitable since the introduction of IEEE-754 in 1985.
It doesn’t have to be this way.
Detached Point Arithmetic (DPA) eliminates rounding errors by performing all arithmetic using integers, tracking the decimal/binary point position separately. The result is exact computation using simpler hardware.
This work is released freely by Patrick Bryant and Pedantic Research Limited. We believe fundamental improvements to computing should benefit everyone.
The Problem
Consider this simple calculation:
float a = 0.1f;
float b = 0.2f;
float c = a + b; // Should be 0.3, but it's 0.30000001192...
This isn’t a bug - it’s the fundamental limitation of representing decimal values in binary floating-point. The error seems small, but:
- In finance: Compound over 30 years, lose $2.38 per $10,000
- In science: Matrix operations accumulate 0.03% error per iteration
- In AI/ML: Training takes 15-20% longer due to imprecise gradients
“This error is small in one operation—but massive across billions. From mispriced trades to unstable filters, imprecision is now baked into our tools. We can change that.”
The DPA Solution
The key insight: the position of the decimal point is just metadata. By tracking it separately, we can use exact integer arithmetic:
typedef struct {
int64_t mantissa; // Exact integer value
int8_t point; // Point position
} dpa_num;
// Multiplication - completely exact
dpa_num multiply(dpa_num a, dpa_num b) {
return (dpa_num){
.mantissa = a.mantissa * b.mantissa,
.point = a.point + b.point
No rounding. No error. Just integer multiplication and addition.
Representation
Any real number x can be represented as:
where:
- m \in \mathbb{Z} (integer mantissa)
- p \in \mathbb{Z} (point position)
Operations
Multiplication:
Addition:
where p_{max} = \max(p_x, p_y)
Division:
The mathematics is elementary. The impact is revolutionary.
Implementation
Here’s a complete, working implementation in pure C:
* Detached Point Arithmetic
* Created by Patrick Bryant, Pedantic Research Limited
* Released to Public Domain - Use freely
#include <stdint.h>
typedef struct {
int64_t mantissa;
int8_t point;
} dpa_num;
// Create from double (only place we round)
dpa_num from_double(double value, int precision) {
int64_t scale = 1;
for (int i = 0; i < precision; i++) scale *= 10;
return (dpa_num){
.mantissa = (int64_t)(value * scale + 0.5),
.point = -precision
// Convert to double (for display)
double to_double(dpa_num n) {
double scale = 1.0;
if (n.point < 0) {
for (int i = 0; i < -n.point; i++) scale /= 10.0;
} else {
for (int i = 0; i < n.point; i++) scale *= 10.0;
return n.mantissa * scale;
// Exact arithmetic operations
dpa_num dpa_add(dpa_num a, dpa_num b) {
if (a.point == b.point) {
return (dpa_num){a.mantissa + b.mantissa, a.point};
// Align points then add...
// (full implementation provided in complete source)
dpa_num dpa_multiply(dpa_num a, dpa_num b) {
return (dpa_num){
The complete source code, with examples and optimizations, is available at:
GitHub - Pedantic-Research-Limited/DPA: Detached Point Arithmitic
Real-World Impact
Financial Accuracy
30-year compound interest on $10,000 at 5.25%:
IEEE-754: $47,234.51 (wrong)
DPA: $47,236.89 (exact)
That’s $2.38 of real money lost to rounding errors.
Scientific Computing
Matrix multiply verification (A × A⁻¹ = I):
IEEE-754: DPA:
[1.0000001 0.0000003] [1.0 0.0]
[0.0000002 0.9999997] [0.0 1.0]
Digital Signal Processing
IIR filters with DPA have no quantization noise. The noise floor doesn’t exist because there’s no quantization.
DPA is not just more accurate - it’s often faster:
| Operation | IEEE-754 | DPA | Notes |
| Add | 4 cycles | 3 cycles | No denorm check |
| Multiply | 5 cycles | 4 cycles | Simple integer mul |
| Divide | 14 cycles | 12 cycles | One-time scale |
| Memory | 4 bytes | 9 bytes | Worth it for exactness |
No special CPU features required. Works on:
- Ancient Pentiums
- Modern Xeons
- ARM processors
- Even 8-bit microcontrollers
Future Directions
This is just the beginning. Potential applications include:
- Hardware Implementation: DPA cores could be simpler than FPUs
- Distributed Computing: Exact results across different architectures
- Quantum Computing: Integer operations map better to quantum gates
- AI/ML: Exact gradients could improve convergence
I’m releasing DPA freely because I believe it will enable innovations I can’t even imagine. Build on it. Improve it. Prove everyone wrong about what’s possible.
Acknowledgments
This work was self-funded by Pedantic Research Limited as a contribution to the computing community. No grants, no corporate sponsors - just curiosity about why we accept imperfection in our calculations.
Special thanks to everyone who said “that’s just how it works” - you motivated me to prove otherwise.
How to Cite This Work
If you use DPA in your research or products, attribution is appreciated:
Bryant, P. (2025). "Detached Point Arithmetic: Eliminating Rounding
Errors Through Integer Computation." Pedantic Research Limited.
Available: https://github.com/Pedantic-Research-Limited/DPA
Contact
Patrick Bryant
Dayton, Ohio
Email: [email protected]
GitHub: GitHub - Pedantic-Research-Limited/DPA: Detached Point Arithmitic
Twitter: https://x.com/PedanticRandD
https://buymeacoffee.com/pedanticresearchlimited
“I created DPA because I was tired of computers that couldn’t add 0.1 and 0.2 correctly. Now they can. Use it freely, and build something amazing.” - Patrick Bryant
License: This work is released to the public domain. No rights reserved. Use freely for any purpose.
Patent Status: No patents filed or intended. Mathematical truth belongs to everyone.
Warranty: None. But, If DPA gives you wrong answers, you’re probably using floating-point somewhere. ![]()
