My CPU fan is too low!
Hey everyone. I need help/suggestions for any decent air-based cooler for my CPU that's not blocking my RAM slots.
  • CPU: AMD FX-8350
  • Current cooler: ZALMAN Extreme 110mm Ultra Quiet Slim
  • Motherboard: ASUS Sabertooth 990FX
I'm usually pretty knowledgeable when it comes to building PC's, but I get brain dead when it comes to knowing what to buy for cooling. I figured it'd be good enough to keep the CPU cool while I played games for long periods of time. The PC is in an A/C'd room and I'm not interested in OC'ing anything so the current fan has been doing fantastic.
My issue: The freakin' fan is too low. My dumb self bought a slim fan when I didn't need one. I had to put my 2 sticks of RAM on the farther slots. But now I'm wanting a couple more sticks to install, but there's no way I'll be able to get the slot closest to the CPU to fit anything, unless I replace the cooler.
My question: Anybody have any suggestions on CPU coolers for my CPU? I'd prefer one that is a little higher so I could actually use all 4 slots for my RAM lol. If it helps I'll list the complete specs of my tower.
  • CPU - AMD FX-8350 Vishera 4.0GHz
  • CPU Cooler - Zalman Extreme 110mm Ultra Quiet Slim
  • GPU - HIS IceQ x2 Radeon HD 7970
  • Case - Cooler Master CM Storm Scout 2 Advanced
  • RAM - G.Skill Ares Series 1866 8GB (2 x 4 GB)
  • PSU - Corsair HX Series 750W
  • Motherboard - ASUS Sabertooth 990FX R2.0
Thanks for any help!
EDIT: I'd prefer to keep it under $75 if possible
Most single-fan tower coolers shouldn't have a clearance issue if they're in a pull-configuration.
Here is a shot of my set up. I have a mid-range Dark Knight cooler on my motherboard.
