I'm new to the forum (not new to tek syndicate, I've been following the video's quiet a while now), I don't know if I posted this in the right place but what the heck.
I recently upgraded my pc to an ssd disk to boot windows on, I upgraded my graphics card (from an nvidia 9800 gt to an nvidia geforce 650 ti) and I changed my power supply. Now i installed windows 7 home premium (64 bit). The problem i was having is that after a while around 10 minutes after booting the computer freezes and does nothing anymore. Then the screen goes black while the computer is still running (i hear the fans spinning and extra hard drives running).
I've installed all the drivers, i've tried turning some of them off (when there are two audio drivers installed) this didn't help. I have looked in the eventlog and everytime the computer freezes there is a problem with the kernel power or something. Can somebody help me?
Open up task manager and keep it open when you're doing whatever on your computer. See how much CPU usage you idle at, and how much when you're doing your normal business. If nothing appears to be out of normal,get GPU temp (or some other program that monitors GPU ram usage) and see how much of your GPUs ram is being used when doing nothing and when going with your normal busines.
I have the exact same graphics card and whenever I play a game for more than 3 hours, my GPU ram usually gets to 99% and everything begins to slow down, and freeze, and sometimes can recover by closing the program.
when doing nothing at all cpu is at about 2-3 % and the ram takes up about 765 mb. When chrome, word and vlc are open cpu = 50-70% and ram is at 3gb. Thats the thin even when I am doing next to nothing on my pc it freezes.
My psu is brand new and is not the problem as i had the same problem with my former psu. Current psu is corsair cx500m. thanks for your help so far really appreciate it!
I have downloaded slimdrivers free, there are a lot of my drivers out of date and need updates. I think this is part of the solution only problem is my compter keeps freezing while installing the drivers :-(
If drivers don't fix it,try checking for viruses and if that comes up nothing when you do it 3 times (sometimes it doesn't find it the first time when I try it) disk defrag.
No virusses at all, all drivers installed nothing helped. going to try reinstalling windows this is my last resort i can't think or find anything else :s
