It's not my build exactly. I'm building this for my cousin whose birthday is in a month. He plays games like Warcraft 3, Starcraft, Minecraft, and a few other games not worth mentioning. Here's the build link http://pcpartpicker.com/p/2xCG3. What answers I'm hoping for are things like "Oh don't use that RAM use this instead (insert link here)" or "Here's a better MoBo for about the same price". Things like that. Thanks anyways for any help you can give me.
I would say get some more RAM. 2GB is a bit weak, 8GB would be a good sweet spot.
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148544&clickid=wAWXBV07b3rTS0mVjgRzBxG8UkT1SbVpy0LvwY0&iradid=97618&ircid=2106&irpid=79301&nm_mc=AFC-IR&cm_mmc=AFC-IR-_-na-_-na-_-na
i agree, 8gigabytes of ram power will be good.
for like 5.20 more you can get a 1TB WD Blue HDD. : http://www.amazon.com/dp/B0088PUEPK/?tag=pcpapi-20
As recommended above 8GB is the way to go
Also you could get a NZXT Source 210 (White) for 46$: http://www.newegg.com/Product/Product.aspx?Item=N82E16811146076&clickid=wAP3dq0syWeFyYA3r9SRS2i9UkT1Sdxty25N3A0&iradid=97618&ircid=2106&irpid=79301&nm_mc=AFC-IR&cm_mmc=AFC-IR-_-na-_-na-_-na
I also agree on more RAM
I'd get an A10 APU if you're going to build a PC at this budget... 8GB of ram is standard for most PC builds but 1x4GB might be recommended for a $400 build...
http://pcpartpicker.com/p/2y4Dc
something like that maybe? $400 is pretty damn cheap... you can't expect a lot... but that kind of covers the bare minimum basics... very upgradeable... but really I'd spend the extra $50 on the flagship Kaveri APU (which apparently can play battlefield at 1080p on medium settings...) couple that with a crossfire gpu later, another 4GB ram stick, and you'll have a halfway decent gaming pc...
