My build (Suggestions?)
Any tips on how to improve my build? Budget~ $1,300
Case- Fractal Design Define R5
Mother Board- ASUS z97 -A ATX DDR3 2600 LGA 1150
Video Card- Gigabyte GeFore GTX 970 G1 GDDR5 4G
Hard Drive- WD Blue 1TB SATA 6Gb/s 7200rpm
Processor- i5-4690k 3.5 GHz
Ram- Kingston HyperX FURY 16GB 1866 MHz DDR3
Power Supply- Corsair 750 Watt Modular
CPU Cooler- Corsair Liquid Cpu Cooler h80i
Extra Fans- 2 NZXT 140mm Case Fans
There are a few spots where you could do better but otherwise it is a really solid build.
The big thing here is I added an SSD to the build and dropped the ram down to 8GB instead of 16.
Other modifications include a better heatsink, a better GPU (I think you get a much better card with EVGA), a MUCH better PSU, and no extra fans because you will not need them.
http://pcpartpicker.com/p/n2GnJx
