Hello...
i want to build my gaming / editing pc for 2000$-2300$
http://pcpartpicker.com/user/saudivip/saved/1vVL
is it a good build or not ?
i want to overclock the cpu & gpu is it able to?
if it's bad for gaming / editing and tell me why please.
For that much you can fit a titan in there
http://pcpartpicker.com/p/T1cz
CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor ($229.99 @ Microcenter)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($99.99 @ NCIX US)
Motherboard: ASRock Z77 Extreme6 ATX LGA1155 Motherboard ($154.98 @ Outlet PC)
Memory: Mushkin Redline 16GB (4 x 4GB) DDR3-1866 Memory ($149.99 @ Newegg)
Storage: Samsung 830 Series 256GB 2.5" Solid State Disk ($159.99 @ Newegg)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive ($89.99 @ Newegg)
Video Card: Asus GeForce GTX Titan 6GB Video Card ($1006.13 @ Newegg)
Case: Fractal Design Define XL R2 (Black Pearl) ATX Full Tower Case ($89.99 @ Newegg)
Power Supply: SeaSonic 850W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply ($116.49 @ Newegg)
Optical Drive: LG UH12NS29 Blu-Ray Reader, DVD/CD Writer ($39.99 @ Newegg)
Total: $2137.53
i think titan is overpriced
sli msi 660ti is strong enough
i saw sli 660ti beats titan
not sure if it was real thing or not
Thanks man :)
just get a 680. titan is serious overkill.
for that kind of budget go for a Socket 2011 3930K GTX680.
that amough of money you dont gonne invest in a dead socket...
just 2 of my cents...
Grtz Angel ☺
Don't go SLI from the get go... maybe allow for it in the future (probably won't be practical then...) but SLI can throw out some issues with games and such... In a few cases sli or crossfire will perform worse then just 1 of the original card. (As time goes on I'd expect that games will be better and faster at working with SLI and Crossfire but it isn't worth the investment right now)
I think the best thing you could do for yourself is grab a EVGA 680FTW edition.
http://pcpartpicker.com/p/T2A2
there are problems with the server for combo deals but that will be fixed shortly and the links will work then
if you can't see the combo deals yet what it ammounts to is 4x8GB (32GB) 2400Mhz ram in qaud channel, a overclockable 6 core i7, with a kraken x60 cooling it, which out performs the H100i, a 4GB 680, 1TB HDD, 750w PSU, and a cosair case
thanks every 1 i made my decision ...
ill wait for gtx 780 T_T
well that might be for the best, prices for everything else might come down and you'll have near the performance of a titan
