Hi this http://pcpartpicker.com/p/3dxNq is the build i was planning on building its my first therefore that's why i have monitors and speakers and all of it but any recommendations or opinions are welcome thanks this build is also going to be just for gaming though
http://pcpartpicker.com/p/3dzhf
If you want to overclock your cpu, you should be going with a Z87 platform instead of the B85.
The SSD you chose was okay, but you can get faster for cheaper
The video card you chose is very overpriced. Replaced with a MSI 770 as it will run circles around the 270x.
Changed the power supply as I've seen a few Antec PSUs meet an early end.
Sound card isn't needed. On board sound on ASrock boards will work wonders for your speakers and headset.
