My budget pc build
http://pcpartpicker.com/p/MwMj
This is my gaming build which im planning to assemble next week.....
1> please tell me if evrything is compatible
2> I would like another option with an AMD cpu (gaming as well) if you guys could build one for me @ pcpartpicker....
     BUDGET AROUND 650- 700 $
Thankyou :)
The cpu and motherboard look good.
Have you considered going AMD for the better performance price value?
http://pcpartpicker.com/p/MwVP
thats a build with AMD's 8350. Its the non black edition and is wicked fast for under 200. It'll do splendid for gaming. if someone could just check out the motherboard for me, that'll be great.
http://pcpartpicker.com/p/MwYt
now thats a build with a 7950! That card is extremely fast for that price plus it comes with 2 fans that'll help with overclocking it, and 7950's are very overclockable. the last build had a 7870 which is still pretty fast, but the 7950 is futureproof for a little while longer. with the extra money left over in this build, try find a faster processor so it doesnt take away fps as much. the phenom II 965 is fast, but with that much money left over, you could find something faster. sorry very tired..... too lazy lol
Heres what i put together for you i made a few changes.
i think it balances out the performance and price better.
sorry for lack of explanation i am better at picking parts then i am at saying why.
http://pcpartpicker.com/b/B3K
Yep... With an AMD coup I can afford a btr gpu
Thank you , that's a gr8 build :D!!
http://pcpartpicker.com/p/Mx4y  $708.28  with a Radeon HD 7950 3GB Video Card
i tossed something together i didnt make a super big change to the video card but made a few changes
http://ca.pcpartpicker.com/b/B3K
also, those builds are if you ARENT gonna overclock your cpu. the 965 is a highly overclockable cpu and it gets great performance benefits. if you are gonna overclock the cpu, you wanna look at coopermans build for that.
Just out of curiosity why are you going with the A10? You cant crossfire it with your graphics card, and there are better procsesors for well pure processing. i mean for the same price you might as well get the unlocked version that is clocked at 3.8 or go with an FX.
http://pcpartpicker.com/p/MxPM
purely budget but if he can do better then that it was just a suggestion.
