So when I boot my arch linux install it puts out "/sbin/init does not exist, then puts out a command prompt in root fs, please help me
Seems someone over on bbs.archlinux has solved that:
I found the answer, it was in a stack exchange thread, I just needed to change which partition the kernel thinks is root
I think I made another fuck up, I can't use sudo on my non root account, how do I get it so that it can use sudo?
check if the user is in the wheel group
id
if it isnt, add it
su -c 'usermod -a -G wheel [username]'
check the wheel group is enabled in sudo
su -c visudo
look for
## Allows people in group wheel to run all commands
%wheel ALL=(ALL) ALL
When I type in visudo, in both terminals, both said the command doesn't exist
Install sudo
I can't, the package doesn't show up
edit: nevermind, package showed up
Oh shit, another problem, how do you write kernel parameters to syslinux to boot that way every time? I am also worried nothing will be written to disk? I am scared to issue systemctl reboot -i
