My 2nd build (for gaming)
so, this is my 2nd build, i i think its pretty good, but id like some feedback.
specs:
CPU: intel i7 3820
GPU: asus gtx 770
case: NZXT Source 530
mobo: ASUS P9X79 LE
CPU cooler: cooler master hyper 212 evo
RAM: g.skill 8gb 1600mhz
HDD: 1 tb WD blue
PSU: 550w thermaltake 80 PLUS BRONZE
Socket 2011 for gaming = big waste of money.
Drop down to haswell or an am3 platform. Money saved should go towards a better psu (that thermaltake unit is rubbish - grab a more reliable model/brand) & a ssd.
Great choice is case. They make for such a nice build.
Suggested budget psu's
http://pcpartpicker.com/part/antec-power-supply-hcg620m
http://pcpartpicker.com/part/silverstone-power-supply-st60fes
http://pcpartpicker.com/part/nzxt-power-supply-np1bn0650aus
http://pcpartpicker.com/part/corsair-power-supply-cx600m
cpu & mb
http://pcpartpicker.com/part/amd-cpu-fd8320frhkbox , http://pcpartpicker.com/part/asus-motherboard-m5a99fxpror20
Feel free to ignore this is just a suggestion.
what is the budget of your build?
1500$ CAD ( i already have the ram, psu and HDD from my first build)
but will it run on 550w?
Most single-GPU Intel and AMD systems will do just fine on 550w.
also, would a 300$ haswell cpu multitask as good? because i do alot of cpu intence multitasking, like watching multiple twitch streams and doing other things
ok, thanks
High end LGA1150 CPUs will often outperform low end 2011 CPUs.  An i7-4770k would be just fine.
If you are considering AMD, an FX-8350 would probably be a more appealing option.
My i5-3570K handles 4 twitch streams just fine.  It also handles 20+ teksyndicate chrome tabs just fine as well.
Depends on what 550w unit though mate. There is a vast valley of distance in quality between a thermaltake 550w unit and say a Seasonic 550w unit. Quality of the rail setup, ovp, filtering, ripple etc.
Go cheap on the psu and its asking for disaster.
Remember that the fx series chips require a lot more power than their haswell counterparts - a low wattage unit will struggle with both a high end fx + 770 + everything else, leaving very little room for overclocking.
+1.  Forgot to mention to get a quality PSU that will output it's rated wattage.
so tgis gpu isnt good enough?
http://www.thermaltakeusa.com/products-model.aspx?id=C_00001975
*this
*psu
It probably is, but there are higher quality PSUs out there with a similar price.
but i already have this psu from my previous build
As long as you dont go for a socket 2011 cpu or even an 8350 that psu should be ok. Going the haswell route is the best way to go if you want to keep the psu and have a system that isnt on its limits.
ok, thanks
Whenever I see gaming machine and Intel in the same place I shake my head. The way I look at it there's only two reasons to go Intel now.
1. You do workhorse type applications such as rendering.
2. You want an Intel build and don't mind throwing the money into it.
I personally use an Intel/Nvidia build but I also do video editing.
If you're just gonna play games go AMD, save the 4-500 bucks and just copy one of those kill your console builds.
But hey if you feel like spending the money go for it. Intel's a great brand but seriously socket 2011 is a huge waste of money before you do workhorse stuff.
I don't know what the prices are in canada, but these prices are from US. It went a bit over 1500$, but the prices may be cheaper in canada :)
the build: http://pcpartpicker.com/p/2uVzY
First off, i picked a AMD FX 8320, wich is a damn good value atm. for 150$ you are getting 8 cores, wich are really fast, and highly overclockable, and atm, give you excactly same gaming performance as and i5 from intel, but the 8 cores will come in handy multitasking, and in future gaming, since games are starting to utilize 8 cores.
For the CPU cooler i picked a corsair h100i AIO liquid cooler. It will give you etremely good cooling performance, and will allow you to overclock the hell out of tha FX 8320. And for the best temperatures, i also included some nice Arctic silver 5 thermal paste for the maximum heat dissipation
For the motherboard i went with the extreme overclocking in mind, so i picked The ASUS ROG Crosshair V Formula-Z AM3+ motherboard. This is the best of the best for AM3+, and will allow you to get the max OC out of your CPU.
For the RAM, i chose some nice, fast 2400 MHz Mushkin blackline RAM, wich will be great for overclocking.
For the GPU, i chose the ASUS GeForce GTX 780 DCII OC, 3 GB, wich will give you amazing gaming performance for a long time, and will allow you to play even with resolution beyond 1080p, since it has a 3 GB frame buffer. And it will outperform the GTX 770 you chose, and it is a great overclocker with the asus directCU II cooler, and other ASUS's super alloy components :)
For the storage, I went with a nice fast A-DATA XPG SX900 128 GB SSD for the OS and a few programs, and for the mainstorage a 1 TB seagate barracuda 7200 RPM HDD
For the case, i went with a Fractal Design Define R4 windowed. It's a great case with sleek look, great airflow, great cable management nice window, easy to work with, and it is quiet. The Red and Black color scheme of the build will look absolutely fantastic in this case, and you would also add some leds to make it look even more cool.
To power the system, i picked a 750W 80+ gold certified Corsair RM fully-modular PSU. It will power the systeam easily and will provide clean power for the maximum OC out of the 8320 CPU.
The Price includes Windows 8.1 (64bit) OEM, and 2 Corsair SP quiet edition fans for extra airflow
Total: $1566.58 USD
I hope i helped and have a great time with your build whatever you choose :)
If you are not into overclocking, then you can save a lot of money, from the MOBO and the CPU cooler, and you will still get a extreme gaming performance :)
