Hi guys! New to the forum and I wanted to see if I'm on the right track with my 1st build. I am build a computer for gaming and photoshoping as well as some light video work. I will moslty be playing WoW, Skyrim, Metro 2033 and any new awesome titles for 2013 and Star Citizen when released. Had a couple questions about a few components. Heres the list:
Case - Bitfenix Colossus
Mobo - Asus Sabertooth z77
Proc - Intel core i7 3770k
Gpu - Evga gtx 670 4gb FTW
Ram - Corsair Dominator Platinum 1600 16GB
Psu - Corsair AX750 750W
OS and Games Drive - Kingston HyperX 120GB SSD
Cpu Cooler - Corsair H100i
Sound Card - Asus Rog Xonar Phoebus
UPS - CyberPower Intelligent LCD Series GreenPower UPS
Ok so my questions are:
Will the single GTX 670 FTW be able to handle gaming at 1080p in Surround?
If I SLI 2 GTX 670 FTW's do you think it could handle surround in 1440p?
Is that ram compatible with the Sabertooth z77, its not on the list but seems like I've seen others using it with the board. Why would their be an issue and if there is what ramifications would it have to use it anyway?
I have concerns about the case, I really like the look and feel but I worry about heat levels as it has the door on the front, do you think I could have heat issues with the GPU? I will be getting the windowed version of the case so I could put fans on the door although I don't want to.
Do the fans on the motherboard push dust inside the thermal armor? Do I need to have them installed at all, does it really help with cooling all that much?
Has anyone used the UPS I listed or does anyone suggest a different one?
Overall does this seem like a good configuration for what I plan to do with it?
If I left anything out that you need to know sorry just yell at me and I'll provide the info. Thanks for you help!
