Multiple Users Programs?
Ok I have a question I have been looking for a program "list of names and dates" that multiple users can use and edit at the same time. This ways someone dos not override work and multiple people can work on one thing. I know there is something out there and I feel like a noob asking this but i need some help with this.
Dropbox will work. You can share the file and then when there is an overwrite dropbox automaticly downloads the update. For this to work all of you need an dropbox account and dropbox installed. I believe the limit is like 3GBs
but I need something that everyone can see that work that is going on in real time.
Hire a programmer... some basic php/sql will do it, maybe there some open-code that you can start from.
Each company develops their own stuff, maybe buy some from them.
Google Docs could probably do what you are talking about, or what I think you are talking about anyway.  Just set up a spreadsheet with multiple user access.  Should work in real time as well.
there use to be this thing called google wave.
What you're looking for is a revision control software. There are many of these, some are free, most are not.
I will look at it and see if that is what I need but so far just by looking at some YouTube videos of it I think this will work. Thank you!
Thank you this will work for what i need
No sweat.
