Can you not just boot into "Safe Mode with Networking" from the list where you choose Safe Mode? If it doesn't crash in Safe Mode then it's more than likely a driver issue. Just go to Device Manager in Safe Mode and enable/disable one driver at a time then boot normally to isolate which driver is causing the issue. Start with the more probable drivers like chipset/NIC/sound drivers.
i directed him to a specialized tech help forum, I got help from them before on a bsod issue, and they are very knowledgable and patient, and they give very simple, clear instructions. I will get him started there.
You could always try to repair windows from the windows install disk/usb drive. If that doesn't work, and you don't have anything important on your computer it may be easiest to reinstall windows.
Hi ! did you check in the mobo bios, what the settings are ? many mobos have specified display preference upon booting. same thing for net chip, it could have specifics to configure. Some mobo s have a system that check the state of the network connection upon booting.
Cheers
PS sounds like problems I had with some rigs with built-in graphics.
Thanks everyone! maxcat, you reminded me of this thread. I forgot about it until you responded. The problem was that, since it was my first ever build, I didn't even INSTALL any driver at all! I did a new OS install, because my instincts said so, then I installed the drivers that came with all my discs. Then again, I was 16 years old and never followed what Commissar said IIRC. But that was almost 3 years ago. Now I am quite capable around computers, I even work in IT, lol.
I guess I've been much more of a lurker than an active user. I always ask for help, then kinda do my own thing.
better late than never. Cheers :-) asking questions is the best learning process I know. and than solving it yourself; never better served but by ourselves. (just a thought)
