Multiple Chassis Fan Control
I'm a total noob when it comes to this stuff so don't be afraid to sound condescending,
 Basically i'm buying some parts next weekend for my first official PC build,  (i've messed around with old PCs in lab classes before) but here is my problem
1. I want to know if there is a way i can connect at least 6 of 8 of the fans in the case to the motherboard connectors so that i can find a software to manage them with, i've read that there can be some issues with it and i may have to buy extra cables/adapters, if so listing what i'll need would be greatly appreciated
2. If i were to buy a drive bay fan controller, is there a way i can link multiple fans to a single Dial and still be able to get max RPM from each fan
3. If i were to forget about the fan control, Is there any chance I could have to buy a separate cable/adapter if i want to make a push/pull config with my heatsink, i don't know if i've to do something special to get them working together, i've never tried it before so i don't know what trouble to expect.
Specs
Case : Zalman Z11 with 6 case Fans [ 4x120mm, Front(in) Bottom(in) Top(out) Back(out) 2x80mm, Sides(out) ]
CPU Cooler: CM hyper 212 evo with a push pull config (2x120mm Corsair SP120, just had some lying around)
Mobo: MSI Fm2 a75ma e35- 3 Fan Connectors
Thanks in Advance ^_^
